Bodack
Jan 18, 2022Guide
RBS40v Keeps disconnecting Alexa?
Hey all, My Orbi voice keeps randomly disconnecting from alexa in general. As I reset up it works for a little bit but then a day later it randomly says to check alexa / orbi app settings. For what...
Sfuriya
Nov 28, 2022Aspirant
Did you ever find a solution? I get this all the time. When I can be bothered I reinstall Alexa and then she works for a few minutes and then it’s back to “I’m sorry - I’m having a hard time understanding right now” and then I give up.
The satellite is working fine just not the Voice part.
culpeperlefty
Jan 28, 2023Aspirant
Same exact problem wondering if any solutions. If I turn off the Orbi Voice Alexa works for a short time but then defaults to "Sorry I'm having a hard time understanding right now. For help go to the Orbi app"
- CrimpOnJan 28, 2023Guru - Experienced User
Is this a typing error? ("off")
- BodackJan 28, 2023GuideI never had a solution and netgear repeatedly picked inconvenient times for me to troubleshoot to help fix. I wonder if they would ever offer me a device that just.. worked.
He is right thought power on and off the device it might work for an hour then it resumes to not know anything- culpeperleftyFeb 09, 2023Aspirant
Not sure how but it seems to be working correctly now.
