PB21UK
Mar 25, 2019Tutor
RBS40V latest firmware RBS40V-V2.3.0.10_1.0.1 update failure
Has anyone tried the latest update, I cant update with this file in auto update online mode or manually I am at version 08 at present.
- Mar 26, 2019
Finally, it went through but showed as failed, I tried a second time and then it succeeded. I updated via the web interface on the router and selected the satellite voice as the one to update but manually. The auto update kept failing.
michaelkenward
Mar 26, 2019Guru - Experienced User
I completed the update to V2.3.0.10_1.0.1 yesterday.
I just followed the usual strategy.
What happens when you try, and where does it go wrong?
RBS40V Firmware Version 2.3.0.10 | Answer | NETGEAR Support
What Orbi router do you have?
Are you starting the update from the router or from the satellite's graphical user interface (GUI)?
PB21UK
Mar 26, 2019Tutor
- michaelkenwardMar 26, 2019Guru - Experienced User
That seems to be having a problem all round for different Orbi devices.
