SnoBoyBB
Aug 12, 2022Aspirant
RBS40V latest firmware update fails, even manually!
RBS40V latest firmware 2.6.2.8 fails automatic update and the downloaded file when trying a manual update doesn't contain a .img file. When I get the .ZIP file, there are only the two files RBS40V-V2...
- Aug 12, 2022
SnoBoyBB wrote:
RBS40V latest firmware 2.6.2.8 fails automatic update and the downloaded file when trying a manual update doesn't contain a .img file. When I get the .ZIP file, there are only the two files RBS40V-V2.6.2.8_1.0.1.chk and RBS40V-V2.6.2.8_1.0.1_Release_Notes.html.inside the ZIP file. Updating requires an .img file.Even the previous firmware file has no .img file in it.
Unfortunately, Netgear engineers chose to use different file extensions for firmware images. The original Orbi products used *.img for their firmware file names. Other products, such as the RBS40V (and many, many others) use *.chk
When I update the RBS40V, I connect directly to the satellite using its IP address, then select the menu item Firmware Update. When told to Browse to find the file, select that *.chk file.
Aug 12, 2022Guru - Experienced User
What FW is loaded currently on the RBS40v?
What browser are you using to send the FW file to the RBSs web page?
Try changing the .chk to a .img and then see if the RBS will accept the file using the web browser...
