Rsheldon
Oct 25, 2022Aspirant
RBS40V not powering up - just clicking noise - no lights
Woke up in the morning to find devices connected to RBS40V not working - looked at the RBS40V satellite - i can just hear clicking noise, no led and lights on top rings. Looks like it is a dead dud....
Oct 25, 2022Guru - Experienced User
What clicking? The actual router or the power supply?
Have you checked its power supply? Try different outlets. Or even try one of the power supplies from the satellites.
Rsheldon
Hi,
Thank you for your message. Tried various outlets. The noise I get is from the RBS40V satellite unit, not from the power supply- if I turn off the unit using the small black push button on RBS40V, the noise stops even though the power supply is plugged in.
The noise is like tick..tick..tick.. nonstop. Another posting has something similar but no solution- https://community.netgear.com/t5/Orbi/RBS40V-Not-working-after-power-outage/m-p/2055142#M127222
Please do let me if there’s any solution. Thanks.
- KevinLiTOct 26, 2022NETGEAR Moderator
Hello Rsheldon,
Welcome to the NETGEAR Community!
I understand that you are having issues with your RBS40V.
Please PM the following information so I can endorse you to our support team:
Name:
Email:
Phone Number:
Device Model:
Firmware:
Serial Number:
Preferred time to be contacted:
App version:
Please provide this information as soon as possible!
I look forward to hearing from you!
Best,
Kevin
Community Team
