svmcl
Feb 10, 2021Tutor
RBS40V Not working after power outage
My Orbi Voice worked perfectly until after power came back, the Orbi didn't turn on anymore It seems something might have burn or so, because pressing the power button at the back of the unit produc...
CrimpOn
Feb 10, 2021Guru - Experienced User
svmcl wrote:My Orbi Voice worked perfectly until after power came back, the Orbi didn't turn on anymore
It seems something might have burn or so, because pressing the power button at the back of the unit produces a clicking sound as a relé that is constantly switching on and off.
That's the only thing the Orbi Voce does being plugged and turned on. the annoying sound and nothing else.
I already checked the AC adapter and it's supplying between 18.5 and 19.3 Volts to the unit, so I fairly assume is not the AC Adapter.
Any ideas if there's something like a fuse that can be easily changed?
I tried to dissasemble the unit, but seems there're additional screws hidden elsewere.
The product data sheet describes the RBS40V power supply as "12v/2.5A" (on page 4)
https://www.netgear.com/images/datasheet/orbi/RBS40.pdf
Might want to check it again.
- svmclFeb 11, 2021Tutor
It's an Orbo Voice. Hence, the model is RBS40V
- FURRYe38Feb 11, 2021Guru - Experienced User
Please visit and post about this over in the Orbi with Voice forum:
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
Thank you.
- vajimFeb 11, 2021Master
you may want to post about this over in the Orbi with Voice forum:
