svmcl
Feb 10, 2021Tutor
RBS40V Not working after power outage
My Orbi Voice worked perfectly until after power came back, the Orbi didn't turn on anymore It seems something might have burn or so, because pressing the power button at the back of the unit produc...
Chuspemar
Apr 05, 2021Tutor
svmcl wrote:My Orbi Voice worked perfectly until after power came back, the Orbi didn't turn on anymore
It seems something might have burn or so, because pressing the power button at the back of the unit produces a clicking sound as a relé that is constantly switching on and off.
That's the only thing the Orbi Voce does being plugged and turned on. the annoying sound and nothing else.
I already checked the AC adapter and it's supplying between 18.5 and 19.3 Volts to the unit, so I fairly assume is not the AC Adapter.
Any ideas if there's something like a fuse that can be easily changed?
I tried to dissasemble the unit, but seems there're additional screws hidden elsewere.
Any help will be kindly appreciated.
Hi svmcl
I've had exactly the same problem, but no power outage before fail.
I've reported to Netgear Support and I'm still waiting for answer.
Have you find any solution?
Thanks.
Sdgnj2021
May 23, 2021Aspirant
Had the same issue. Frustrating- this is not a cheap device.
