Toff14's avatar
Toff14
Follower
Mar 02, 2020
RBS40v on fw 2.3.6.4
Orbi Satellite (RBS40V) connection seems to drop and ring turns to magenta occassionally (about once a day). Connection is fine once it is restarted but seems odd to require a restart almost everyday...
  • FURRYe38's avatar
    Mar 02, 2020
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only by un-checking the check box. Save settings and reboot the router and satellite(s).
    Has a factory reset and setup from scratch been performed since last update?
    Satellite is connected to router via ethernet backhaul, hence can't be distance issue.
    Noticed that this started happening after fw upgrade to 2.3.6.4 for satellite and 2.5.1.18 for RBR50.
    Anyone else encountered this and any suggested fix.
