Michal_
Jul 20, 2020Aspirant
RBS40V touch controls not working
Dear Community, I am facing a problem with RBS40V-200 and the control panel stopped working just in beginning of the pairing process with the orbi router. The controls have worke initially, when I ...
Desert_Dave
Aug 12, 2020Aspirant
Thanks for the tip about the newer firmware for the RBS40V. I upgraded it to V2.5.1.6 but this did not help. Wifi is connected and Alexa works but the touch control on top is still not working for volume, mute, etc.
Mstrbig
Aug 12, 2020Master
Find the IP address of the orbi voice. in your browser type 192.168.1.xx<- the ip adress/debug.htm, example 192.168.1.15/debug.htm and try Upgrade Touch Board Firmware.
- Desert_DaveAug 13, 2020Aspirant
It worked! The touch control/lights are working now. Thank you so much for the solution. Hopefully I would not have to do this frequently.
Mstrbig wrote:Find the IP address of the orbi voice. in your browser type 192.168.1.xx<- the ip adress/debug.htm, example 192.168.1.15/debug.htm and try Upgrade Touch Board Firmware.
- MstrbigAug 14, 2020Master
Desert_Dave wrote:It worked! The touch control/lights are working now. Thank you so much for the solution. Hopefully I would not have to do this frequently.
Great please mark as solution so others can benefit from the results
