Michal_
Jul 20, 2020Aspirant
RBS40V touch controls not working
Dear Community, I am facing a problem with RBS40V-200 and the control panel stopped working just in beginning of the pairing process with the orbi router. The controls have worke initially, when I ...
Parha1m
Sep 18, 2020Aspirant
Did you have a fix on this issue? I have the same problem with MyBalanceNow
- MstrbigSep 18, 2020Master
Parha1m wrote:Did you have a fix on this issue? I have the same problem with MyBalanceNow
Did you try?
@Mstrbig wrote:
Find the IP address of the orbi voice. in your browser type 192.168.1.xx<- the ip adress/debug.htm, example 192.168.1.15/debug.htm and try Upgrade Touch Board Firmware.
- tommyshelbyopOct 16, 2020Aspirant
the solution has already been shared
