sandy641's avatar
Nov 11, 2020
RBS40v won’t connect to Ring Doorbell
I have a Ring Doorbell with a weak signal. I bought an Orbi router and Orbi voice and the Ring is online.
However, the ring can’t find the Orbi. The Orbi voice can’t find the doorbell. I moved my Echo into another room.
The problem is that the Orbi voice doesn’t announce or chime that someone is at the door. I’m not sure that my Echo chimes since it is in another room.
I go to “skills” and discover with no luck.
Any ideas?
