mwisch
Jun 02, 2023Aspirant
RBS40V won't pair with RBR20 in Satellite (Orbi) mode.
I can connect to it in Extender mode but when I switch to Orbi mode it pulses white and never goes solid white.
CrimpOn
Jun 02, 2023Guru - Experienced User
This is the RBS40V-200 model, correct?
Have you done a Factory Reset on the RBS40V, then switched it into Orbi mode?
https://www.downloads.netgear.com/files/GDC/RBS40V-200/RBS40V-200_QSG_EN.pdf
mwisch
It says RBS40V on the label, no -200. I have done the factory reset and switch to Orbi mode but the ring never goes to solid white. I am wondering if the Orbi version software is corrupt but if I try to manually update it by logging in directly in Extender mode it fails.
- CrimpOnJun 02, 2023Guru - Experienced User
I am really confused.
The RBS40V (without the '200') and the RBS40V-200 both appear to have two different firmware versions:
Yet they have entirely different installation directions:
RBS40V: https://www.downloads.netgear.com/files/GDC/RBS40V/RBS40V_QSG_EN.pdf
These instructions make no mention of Orbi vs. Extender mode.
Likewise the Product Data Sheet for the RBS40V makes no mention of "Extender Mode".
RBS40V-200: https://www.downloads.netgear.com/files/GDC/RBS40V-200/RBS40V-200_QSG_EN.pdf
These instructions have definite steps to change the mode to either Orbi or Extender and state that the ring light at the top will flash blue/white in extender mode and white/white in Orbi mode.
The Product Data Sheet for this model adds "works with any WiFi router":
I have this horrible suspicion that there actually is a significant difference between the RBS40V and the RBS40V-200.
Where did this Orbi Voice come from?
- Purchased as New?
- Purchased as Used (eBay for example)
- Gift from someone?
- mwischJun 05, 2023Aspirant
It definitely defaults to extender mode (solid blue ring). The instructions to change to Orbi mode also work EXCEPT the ring never goes solid white, just pulsing. I want to use it as part of my existing Orbi mesh, not as an extender.
I purchased as used from Amazon. Can't get direct support from Netgear. I hate to return it but am running out of options.
- FURRYe38Jun 05, 2023Guru - Experienced User
What FW is on the RBR20?
The RBS40v should connect however it may need to be loaded with same version of FW as what is on the RBR20.To make the RBS40v connect and integrate as a satellite, Seems like the RBR20 and any RBS20s would need to be first downgraded to FW v2.6.2.104 and have the RBS40v loaded with v2.6.2.8, Then I presume the RBS40v should connect wirelessly to the RBK20 system.
The RBS40v and RBS40v-200 are just same units. Have same FW versions. Its the operation mode that has different FW versions.
