OldManJitsu's avatar
OldManJitsu
RBS50 - Adding one more Sonos Play1 drops internet connectivity after awhile
Using Firmware v2.1.1.16 with the RBR/RBS50.  Connectivity is all working, have multiple switches downstream of the RBR, with multiple devices either plugged in via ethernet or connected wireless.  Currently 18-19 devices are all connected either wirelessly or wired.  Devices range from QNAP nas, computers & laptops, home theater system, various Sonos devices, iphones/samsungs, tablets, etc.
Issue comes with adding another Sonos Play:1.  I already have an old 90, 120, 2 Play:1's, and a Play:3 all in different rooms, all wired directly into switches.  If I add the last Play:1 via hardwire cable, again in another room,  then by the next morning, my internet is down and I need to unplug the last Play:1, and reboot the Orbi.  Wireless still works, but does not provide access to the internet.
I've checked to make sure I do not have an ip address conflict, using DCHP so wouldn't think I would, and WAN/LAN range has more than enough free IP addresses to assign, but not sure of what else to check???  I do see some Dos Attack: ACK Scan in the log, but that's with the Play:1 not connected.
[DoS Attack: ACK Scan] from source: 69.16.175.10, port 80, Friday, January 12, 2018 18:46:30
[UPnP set event: del_nat_rule] from source 192.168.1.100, Friday, January 12, 2018 18:45:12
[DoS Attack: ACK Scan] from source: 69.16.175.42, port 80, Friday, January 12, 2018 18:44:46
[UPnP set event: add_nat_rule] from source 192.168.1.100, Friday, January 12, 2018 18:44:09
[DoS Attack: ACK Scan] from source: 69.16.175.42, port 80, Friday, January 12, 2018 18:43:12
[UPnP set event: del_nat_rule] from source 192.168.1.100, Friday, January 12, 2018 18:42:03
[UPnP set event: add_nat_rule] from source 192.168.1.100, Friday, January 12, 2018 18:41:00
[DHCP IP: 192.168.1.110] to MAC address 84:ef:18:86:36:e3, Friday, January 12, 2018 18:39:41
[UPnP set event: del_nat_rule] from source 192.168.1.100, Friday, January 12, 2018 18:38:40
Any help would be greatly appreciated.
  • Do one of the following.
    1) Disconnect all Sonos from wired ports and set Sonos to use your WiFi, or
    2) Disconnect all Sonos and wire only ONE Sonos device to Ethernet, and manually set Sonos to use Channel 1 and set Orbi to use Channel 11 in 2.4 GHz, or vice versa.
    • OldManJitsu's avatar
      OldManJitsu
       Thanks for responding, but still confused.  If I have 5 of my 6 Sonos devices working correctly through hard wired connections, why do I need to switch all of them to use wifi?   Don't understand why the 6th seems to kick my internet down.
      I also don't have a Bridge or Boost, but can attempt to set up all of them through existing wifi in the advanced settings.  Though not sure older sonos devices will recognize that, and that is not preferred, as I have a large house and they are spread out inside and outside, through multiple floors.  Hence the hardwire connections when we remodeled the house.
      Will see what I can figure out tomorrow morning with your suggestion.  Thanks.
      • timch's avatar
        timch
        Luminary
        I have found Sonos to be very sensitive to ip conflicts so to avoid issues, ensure you start with all Sonos items powered off and then restart your router.  You should then add your wired Sonos item an then power up the rest.
        as said above, it is very unwise to have more than 1 wired Sonos item to avoid loops.
