jtsock
Jul 16, 2023Aspirant
RBS50 - Continually Blinking White Including After Reset
Hi, My RBS50 (up to now working mostly flawlessly for 3 years or so) dropped off the network last night and started blinking white on the ring. I tried a couple of power cycle, and then a reboot on t...
Jul 16, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
