baldmagicguy
Mar 25, 2020Star
RBS50 - static device hardwired to a satellite is not showing up in attached devices.
I've got an RBR50 with 2 RBS50 satellites. I have a security camera with a static IP hardwired to one of the satellites. The camera pings and is working fine, but it does not show up at all as an a...
tomschmidt
Mar 25, 2020Virtuoso
Are you using a wired backhaul, or using the wireless backhaul? I have one of my RBS50 satellites using a wired backhaul to the RBR50 router, and I have a wired PC attached to that satellite. Perhaps the backhaul type may affect this?
- baldmagicguyMar 25, 2020Star
Thanks, Tom, for your reply.
I'm using the wireless backhaul. Using a wired backhaul isn't an option unless you'd like to volunteer to come pull cable. :smileyvery-happy:
Cheers,
Marty
