baldmagicguy
Mar 25, 2020Star
RBS50 - static device hardwired to a satellite is not showing up in attached devices.
I've got an RBR50 with 2 RBS50 satellites. I have a security camera with a static IP hardwired to one of the satellites. The camera pings and is working fine, but it does not show up at all as an a...
CrimpOn
Mar 26, 2020Guru - Experienced User
baldmagicguy wrote:I have a security camera with a static IP hardwired to one of the satellites. The camera pings and is working fine, but it does not show up at all as an attached device when logged into the router as admin. It's missing from "Attached Devices" in both Basic and Advanced views.
These technical puzzles just cry out for a "reason why." Does the satellite web page "Connected Devices" display show the camera? (I just love that after three years, the router calls them "Attached" devices and the satellite "Connected" devices.)
baldmagicguy
Mar 26, 2020Star
Ha! I hear you.
When connected directly to the satellite, the camera does show up with a device name of "Unknown."
- CrimpOnMar 26, 2020Guru - Experienced User
baldmagicguy wrote:
When connected directly to the satellite, the camera does show up with a device name of "Unknown."Yes, this is another one of those "Orbi Things" that people have been posting about. For some unknown reason, the information we have so carefully entered into the router to describe devices do not propogate to satellites. This is "normal". Surely the device has data packets passing through the router?
- baldmagicguyMar 26, 2020Star
CrimpOn wrote:
LOL! Oh.... you could say there's one or two packets passing through the router. I have an NVR hardwired to the router that records all my cameras. There's a constant video stream running throught the router to the NVR.
Everything works perfectly except for the camera showing up in the attached device list.
- theoakMar 26, 2020Luminary
I have a wifi garage door opener that behaves like this. See my config in my signature. It shows up in my personal router, from the Orbi app however (web or iOS) it would not show up. The door sends to notifications via its app when the door is opened or closed. So it is clearly connecting to my wifi and the internet. Its success rate on showing up in the Orbi iOS app I would say is around 50%; like you, it is more like an annoyance. Today - Orbi sees it.
theoak wrote:I have a wifi garage door opener that behaves like this. See my config in my signature. It shows up in my personal router, from the Orbi app however (web or iOS) it would not show up. The door sends to notifications via its app when the door is opened or closed. So it is clearly connecting to my wifi and the internet. Its success rate on showing up in the Orbi iOS app I would say is around 50%; like you, it is more like an annoyance. Today - Orbi sees it.
So your issue is just with the app, correct? I'm not seeing it at all with both the web interface and the app. My success rate is 0%.
Why is it the simple things get to me? LOL! I may never know.
