apolci01
Oct 03, 2022Aspirant
RBS50 - We just added an additional satellite to our Mesh system it keeps disconnecting
We just added another Satellite to our Mesh system. Therefore I have my router and 2 satellites now. Our house is 4160 (2 stories) our router is on the 1st floor. We have always had a Satelli...
CrimpOn
Oct 03, 2022Guru - Experienced User
Also, it would be helpful to know how the two satellites are connecting:
- Are they both connecting directly to the router? or
- Is one satellite connecting to the other satellite?
This will be revealed in the Orbi 'app' Network Map or the web browser interface Attached Devices page.
apolci01
I also checked and the 2 satellites are connecting directly to the router...
- KevinLiTOct 04, 2022NETGEAR Moderator
Hello apolci01,
Thank you for your reply!
Since your firmware is that low you will have to do incremental updates to get the firmware for your router up to date. Update your satellites starting with firmware version 2.0.0.74 then proceed with incremental updates until your firmware is updated to firmware 2.7.4.24.
Please visit the page below for firmware supported by your RBS50:
https://www.netgear.com/support/product/RBS50.aspx#download
Best,
Kevin
Community Team
