britgeezer
Oct 25, 2019Tutor
RBS50 - where to purchase a 2nd unit
I purchase the router and satellite package - but there is a section of the house where the signal is not great and I could use the LAN ports. Where to get a 2nd RBS50 without paying almost the same...
- Oct 28, 2019
Thanks for the answers. I figured that any could be used but I wanted to have a 3rd mesh unit and have since aquired a used unit.
I find it a bit of a Netgear ripoff that additional RBS50 satelittes are so expensive compared to the original Router Plus S package.
However we all have a choice in the matter :)
michaelkenward
Oct 26, 2019Guru - Experienced User
You can add any Orbi satellite that is within your budget. You don't have to have another RBS50.
britgeezer
Oct 28, 2019Tutor
