Shayzeke
May 20, 2022Follower
RBS50 Add on Satellite
I have an existing RBR50v2 router with one RBS50v2. I’m trying to add another RBS50 satellite that I purchased from eBay and I can’t get it to connect. Do I have to reconfigure the add on which appear...
CrimpOn
May 20, 2022Guru - Experienced User
Most users get out a paperclip and do a Factory Reset on the new satellite, then follow the instructions to Add Orbi Satellite.
- CrimpOnMay 20, 2022Guru - Experienced User
p.s. There is nothing to configure on satellites. They get all configuration from the router once they are sync'd to it.
