Shayzeke
May 20, 2022Follower
RBS50 Add on Satellite
I have an existing RBR50v2 router with one RBS50v2. I’m trying to add another RBS50 satellite that I purchased from eBay and I can’t get it to connect. Do I have to reconfigure the add on which appear...
CrimpOn
May 20, 2022Guru - Experienced User
Most users get out a paperclip and do a Factory Reset on the new satellite, then follow the instructions to Add Orbi Satellite.
CrimpOn
p.s. There is nothing to configure on satellites. They get all configuration from the router once they are sync'd to it.
