Shayzeke
May 20, 2022Follower
RBS50 Add on Satellite
I have an existing RBR50v2 router with one RBS50v2. I’m trying to add another RBS50 satellite that I purchased from eBay and I can’t get it to connect. Do I have to reconfigure the add on which appear...
May 20, 2022Guru - Experienced User
Sometimes it helps to hardwire it in and sync it. once its added, you can try disconnecting it
