Shayzeke
May 20, 2022Follower
RBS50 Add on Satellite
I have an existing RBR50v2 router with one RBS50v2. I’m trying to add another RBS50 satellite that I purchased from eBay and I can’t get it to connect. Do I have to reconfigure the add on which appear...
KevinLiT
May 25, 2022NETGEAR Moderator
Hello Shayzeke,
I understand that you are having issues connecting your third-party purchased RBS50 to your RBR50. All that is required for this device to sync to your RBR50 is a factory reset. After you have conducted a factory reset please navigate to the link below for instructions on how to sync the satellite to your existing network:
How to sync Orbi router and satellite:
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
Please let me know if you have any additional questions!!!
Best,
Kevin
Community Team
