neo_geo's avatar
neo_geo
Tutor
Jul 21, 2021
RBS50 Add on Sattelite
I puchased a Orbi system bundle with a router (RBR50) and 2 sattelite (RBS50) a while back.  I added an outdoor sattelite without any issues.  Recently, I tried to add one more sattelite.  This satte...
  • FURRYe38's avatar
    FW on the new RBS may be older and thus not able to sync with whats currently being used.
    Try this with the new RBS50:
    What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite📡. Already have the most current FW version files downloaded on to this PC.
    Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite📡. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites 📡 web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites 📡 to the RBR.
