Stallion69's avatar
Oct 19, 2020
RBS50 Additional Satellite
I curently have an ORBI mesh system set up in my home.  I have the RBR50 router with 2 RBS50 satellites.  Router is located in the basement and the two satellites are on the main floor.  I Hard wired the two stellites to the back of the Orbi Router (Back Haul).  I noticed that some people connect both satellites to an ethernet switch and the RBR50 connects to the ethernet switch as well.  I hope the way i connected it is good.  Anyhow, my question is I wanted to add a third satellite in my basement to the RBR50 router. Can the router handle 3 Ethernet connctions from 3 satellites?  Also, if Ichoose not to run an ethernet cable to the third satellite, will it still work, even though the other two satellites on the main floor are hard wired to the RBR50 router? I think if the third satellite is hard wired to the routher as well, speeds will be faster.  Anyhow, looking for feedback and advice before I purchase an additional RBS50 satellite.  I cancelled my RBW30 plug in satellite after reading some reviews and experiences people went through.  And the speed of the RBW30 will not be as fast of the RBS50.  Thanks.
    • Stallion69's avatar
      Stallion69
      Tutor
      Thanks for the response.  So in other words, as soon as i turn on the third RBS50 satellite, it should sink with the ORBI RBR50 router, correct? Then three satellites will show up on my ORBI app, correct?
      • FURRYe38's avatar
        Theoretically yes the RBS should, however, technically, since NG design that requires the RBR and RBS to be on the same FW version for each other, if a new RBS is introduces, this one RBS may be using older versions of FW. Thus needs to be updated first to same version as whats currectly being used on your RBR/RBS. Then it should connect well.
        IF this is the case, try the following:
        What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
        Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
