Stallion69
Oct 19, 2020Tutor
RBS50 Additional Satellite
I curently have an ORBI mesh system set up in my home. I have the RBR50 router with 2 RBS50 satellites. Router is located in the basement and the two satellites are on the main floor. I Hard wired...
Stallion69
Oct 19, 2020Tutor
Okay. Hopefully it works without all the stuff you mentioned. Thanks for the advice.
DeanB1452
Oct 20, 2020Apprentice
I have a RBR50 with two RBS50's, one wired, one wireless. I also have a wired RBS20 on the same mesh network. All are working fine. You shouldn't have any problem adding a third RBS50 into your system whether it is wired or wireless. Just check the backhaul status if you are going wireless, just in case you need to move it closer because of obstructions.
- Stallion69Oct 21, 2020TutorI will hardwire it.
- FURRYe38Oct 21, 2020Guru - Experienced User
Let us know how it goes...
Yes i will. Thanks for all your help and advice.
