Stallion69
Oct 19, 2020Tutor
RBS50 Additional Satellite
I curently have an ORBI mesh system set up in my home. I have the RBR50 router with 2 RBS50 satellites. Router is located in the basement and the two satellites are on the main floor. I Hard wired...
Stallion69
Oct 21, 2020Tutor
I will hardwire it.
Oct 21, 2020Guru - Experienced User
Let us know how it goes...
- Stallion69Oct 21, 2020Tutor
Yes i will. Thanks for all your help and advice.
- herebedragons69Aug 08, 2022Aspirant
How did it go? I want to extend my RBR50 + RBS50 with one more RBS50 satellite as well. Do I understand correctly that you can connect a LAN cable from an RBR50 to any of the ethernet ports in the RBS50 Satellite and it will connect said satellite to the network?
