reinholdmueller
Dec 11, 2017Tutor
Rbs50 and rbr50 did not update to firmware 2.1.1.12
Actually i have firmware 2.0.0.74. i cannot update the firmware automatically nor manually to 2.1.1.12. If i try to do it manually via the web interface, the message did appear, that i have an incorr...
JMU1998
Dec 11, 2017Luminary
reinholdmueller you may have already done this but wanted to mention to check the file type of the 2 files you downloaded if they are zipped the Orbi will not recognize them may have to unzip/extract them to a folder on your machine.
