reinholdmueller
Dec 11, 2017Tutor
Rbs50 and rbr50 did not update to firmware 2.1.1.12
Actually i have firmware 2.0.0.74. i cannot update the firmware automatically nor manually to 2.1.1.12. If i try to do it manually via the web interface, the message did appear, that i have an incorr...
Guillaume_FR
Dec 12, 2017Aspirant
Hi all,
Same issue here :
- downloaded firmware 2.1.1.12 for both RBS and RBR
- unzipped with winrar
=> When trying to load RBS firmware, the page does kind of a refresh after some minutes. I can select again the file. No error message.
I tried downlading the files from another server (US and FR) => Same behavior
I tried under firefox, with and withot adblockplus, and on Edge => Same behavior
I did not try the update of the RBR, as it is mentioned everywhere to update RBS first.
Any hint please?
Naby thanks
- reinholdmuellerDec 12, 2017Tutor
Found thr solution as follows.
first: update the ROUTER RBR50 (i know it is said, that the satellites should be updated first, but this did not work)
second: detach all satellites from the current. Wait 10 seconds. Attach the satellites again to the current and wait until they connect to the router
Third: update now the satellites one by one
good luck. It worked for me
- Guillaume_FRDec 13, 2017Aspirant
Hi!
Thanks a lot for your answer and workaround.
Before doing it, I wanted to try something else: I unplugged the RBS, waited then restarted it. Once connected to the RBR, I tried once again the upgrade procedure, with the expected result!
RBS is now under 2.1.1.12, I will now apply it to the RBR.
Thanks again!- JMU1998Dec 13, 2017Luminary
Good luck let us know how it goes with the new Firmware? I personally don't want to upgrade or get the auto update until the bugs and issues are addressed with v2.1.1.12
