reinholdmueller
Dec 11, 2017Tutor
Rbs50 and rbr50 did not update to firmware 2.1.1.12
Actually i have firmware 2.0.0.74. i cannot update the firmware automatically nor manually to 2.1.1.12. If i try to do it manually via the web interface, the message did appear, that i have an incorr...
Guillaume_FR
Dec 12, 2017Aspirant
Hi all,
Same issue here :
- downloaded firmware 2.1.1.12 for both RBS and RBR
- unzipped with winrar
=> When trying to load RBS firmware, the page does kind of a refresh after some minutes. I can select again the file. No error message.
I tried downlading the files from another server (US and FR) => Same behavior
I tried under firefox, with and withot adblockplus, and on Edge => Same behavior
I did not try the update of the RBR, as it is mentioned everywhere to update RBS first.
Any hint please?
Naby thanks
reinholdmueller
Dec 12, 2017Tutor
Found thr solution as follows.
first: update the ROUTER RBR50 (i know it is said, that the satellites should be updated first, but this did not work)
second: detach all satellites from the current. Wait 10 seconds. Attach the satellites again to the current and wait until they connect to the router
Third: update now the satellites one by one
good luck. It worked for me
- Guillaume_FRDec 13, 2017Aspirant
Hi!
Thanks a lot for your answer and workaround.
Before doing it, I wanted to try something else: I unplugged the RBS, waited then restarted it. Once connected to the RBR, I tried once again the upgrade procedure, with the expected result!
RBS is now under 2.1.1.12, I will now apply it to the RBR.
Thanks again!- JMU1998Dec 13, 2017Luminary
Good luck let us know how it goes with the new Firmware? I personally don't want to upgrade or get the auto update until the bugs and issues are addressed with v2.1.1.12
