drrishisingh
Mar 25, 2020Aspirant
RBS50 as a satellite or extender
Hi, Bought a package deal awhile ago which came with one RBS50 and two RBS20s. I bought two packages so I have two RBS50s. Can i use the second RBS50 as an additional satellite? If so how to do re...
CrimpOn
Mar 25, 2020Guru - Experienced User
You mean pressed both sync buttons, correct?
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
drrishisingh
Correct. Both sync buttons and it does not pair. Any other options?
