kenenos
Jun 25, 2017Guide
RBS50 as a wireless bridge?
Is it possible to use the RBS50 as a wireless bridge? I'm asking because I need to use one of my RBS50s very close to my RBR50 and it seems that leaving them both on causes devices to drop off of the...
st_shaw
Jun 25, 2017Master
The RBS50 functions as a wireless bridge by default--just with an AP built-in. I believe you can turn off the 2.4GHz radio but not the 5gHz radio, because that radio is also used for the backhaul (which you need for the bridge function).
If your devices are very close together can you run a wire?
