soupbones
Feb 12, 2021Tutor
RBS50 as an extender for Altice Gateway modem.
Optimum has just ran fiber to my house and with it came their Altice Gateway modem. I have been getting "BRS_wanlan_conflict.html" errors on most sites I visit, and the Orbi app says I have no intern...
- Feb 12, 2021
The RBS50 units don't have an extender mode. but you can put the primary orbi router (RBR50) in access point mode and then be able to use the router/satellites.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Feb 12, 2021Guru - Experienced User
alokeprasad
Feb 12, 2021Mentor
What if he is unable to disable the WiFi on his cable modem?
Don't know if the Altice cable modem supplied by Optimim has WiFi features .. but if they do, disable it when using the Orbi (in access point mode).
