soupbones
Feb 12, 2021Tutor
RBS50 as an extender for Altice Gateway modem.
Optimum has just ran fiber to my house and with it came their Altice Gateway modem. I have been getting "BRS_wanlan_conflict.html" errors on most sites I visit, and the Orbi app says I have no intern...
- Feb 12, 2021
The RBS50 units don't have an extender mode. but you can put the primary orbi router (RBR50) in access point mode and then be able to use the router/satellites.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
CrimpOn
Feb 12, 2021Guru - Experienced User
alokeprasad wrote:See if they'll (Optimim) give you a plain-vanilla cable modem.
Of find their list of compatible modems on their tech support site and buy one. I have bought mine to avoid paying a monthly fee to my ISP.
Alas, this specific part is a combination fiber ONT/router/WiFi box. Has a fiber connector on the back. (not a cable modem).
With fiber, customers are back in the "have to use the provider's box" situation.
CrimpOn
This site says the default login is "admin" and "admin". (If it is not printed on the label)
https://knowmyrouter.com/altice-labs/fibergateway-gr240bg/
Seems strange (to me) that an ISP would deploy home WiFi systems and not give the customer any method to customize the WiFi SSID. (They expect customers to manually change every device to their choice of SSID rather than make one change on the router?)
- parboFeb 19, 2021Aspirant
I've been questioning Altice for past 2 years now. Their answer is it's in the works where can change everything but not now. Wish I can turn off my WIFI signal and change my SSID and channels but can't.
- plemansFeb 19, 2021Guru - Experienced User
So leave the altice gateway as is and just change the ssid/channels on the netgear.
Its a PITA this time but next time you change routers, you can just use the same ssid.
Unfortunate but might be nicer to have your own ssid
