arn0ld
Oct 14, 2021Aspirant
RBS50 auto change connection type to router RBR50 from 5ghz to 2.4ghz
Hello, I have netgear orbi system with 1 router rbr50 and 2 satellite rbs50. i have used this system for 2 year, no problem. But after updating firmware V2.7.3.22, my rbs50 often change conne...
Oct 14, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
arn0ld
sorry i don't understand clearly. So i should push the small reset button of router and satellite right ?
If i do factory reset, do i lost all my internet config ? The firmware after reseting will be V2.7.3.22 or downgrade to first firmware when it's come out from factory ?
- FURRYe38Oct 14, 2021Guru - Experienced User
arn0ld wrote:
sorry i don't understand clearly. So i should push the small reset button of router and satellite right ? Yes. And on the RBR.
If i do factory reset, do i lost all my internet config ? Yes.
The firmware after reseting will be V2.7.3.22 or downgrade to first firmware when it's come out from factory ? Will be .22
