arn0ld
Oct 14, 2021Aspirant
RBS50 auto change connection type to router RBR50 from 5ghz to 2.4ghz
Hello, I have netgear orbi system with 1 router rbr50 and 2 satellite rbs50. i have used this system for 2 year, no problem. But after updating firmware V2.7.3.22, my rbs50 often change conne...
arn0ld
sorry i don't understand clearly. So i should push the small reset button of router and satellite right ?
If i do factory reset, do i lost all my internet config ? The firmware after reseting will be V2.7.3.22 or downgrade to first firmware when it's come out from factory ?
Oct 14, 2021Guru - Experienced User
arn0ld wrote:
sorry i don't understand clearly. So i should push the small reset button of router and satellite right ? Yes. And on the RBR.
If i do factory reset, do i lost all my internet config ? Yes.
The firmware after reseting will be V2.7.3.22 or downgrade to first firmware when it's come out from factory ? Will be .22
- arn0ldOct 14, 2021Aspirant
thank you very much for support
- FURRYe38Oct 14, 2021Guru - Experienced User
đ
- arn0ldOct 24, 2021Aspirant
problem was happen again after i following your solution. After 10 days the system run as normal ( speed test router and satellite is more than 280Mb/s ), i haven't change router and satellite place and today the internet speed on satellite was problem again. The speed test direct to router is 288mb/s, but the speed test on satellite is 40mb only.
Do my satellite got problem with hardware or firmware
