majormcrae
May 26, 2021Initiate
RBS50 Backhaul status is "CONFIG SYNC"? What does this mean and Consequences?
I added two (2) additional satellites and the backhaul status on both is "CONFIG SYNC". What does that mean and what can I do to getting a "GOOD" status?
- May 26, 2021
Please mark your thread as solved so others will know.
Enjoy.
majormcrae
Thanks. Figured it out. firmware version old on the new satellites. Used IP address to download latest version. Actually I am in process right now. So hopefully it will fix it. Home is 6,000 sqft and with these two additional satellites. All working great. Thanks.
May 26, 2021Guru - Experienced User
Enjoy.
