gb2bg
Sep 24, 2020Aspirant
RBS50 Behaving Weirdly with Wired Backhaul
My satellite's been acting up. At first I was not able to connect to the satellite upstairs in the office (wired Backhaul) thought it was something with the firmware so updated that to 2.7, and everyt...
- Sep 29, 2020
With v70 loaded on my RBK50 system, I am seeing a ARP storm when the RBS is connected with two or more LAN switches in between teh RBR and RBS. I see a short ARP storm with just 1 switch in between then stops. My network has 3 switches in between the RBR and RBS. I've reported this alredy to NG support. This wasn't a problem with v16 loaded or prior versions of FW back to v2.3.0.32 when I first recieved a RBR50. So my one RBS is now wirelessly connected to the RBR in AP Mode. RBS is in the basement and the RBR is on 2nd level.
Mstrbig
Sep 25, 2020Master
gb2bg wrote:
My satellite's been acting up. At first I was not able to connect to the satellite upstairs in the office (wired Backhaul) thought it was something with the firmware so updated that to 2.7, and everything shows fine. The router status page shows everything as connected but the app now doesn't show the satellite as online at all. Both iOS and android apps.
I contacted support about this and they said it is a known bug. Try reooting the orbi system and see if it helps. I had it real bad on both app and WEB GUI. After a couple of reboots and reconfiguring a few devices, it all looks good now.
