JitM
Oct 09, 2020Aspirant
RBS50 Blackhaul status Disconnected
Hi, I have RBR50 Orbi product with one satellite (RBS50). I have been using this product happily since last 2 years No issues whats so over. My main unit is downstair and Satellite is upstais wit...
Oct 09, 2020Guru - Experienced User
Has a power off for 1 minute then back on been performed since last update?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
JitM wrote:Hi,
I have RBR50 Orbi product with one satellite (RBS50). I have been using this product happily since last 2 years No issues whats so over. My main unit is downstair and Satellite is upstais with 37feet distance.
I have started getting intermittent internet drop in my satellite since last few days/week . Intermittently Blackhaul status shows disconnected for RBS50 in webconsole where as iphone app shows satellite is connected with green dots in Network Map.
For example everything was working fine this morning Blackhaul Status was good and Connection Type was 5G but since last 1 hour it is showing Disconnected now. I am sure if I am going to restart satellite it will work again.
I am on Firmaware version 2.5.2.4.
Since i have not made any changes in my house or locations of Orbi system and everything used to work brilliantly until last couple of days, I am wondering if it is related to any bug in new firmware.
Please help!
