treadpool
Oct 30, 2019Tutor
RBS50 blinking white - cannot connect
My Orbi satellite is flashing white and I'm not sure why. I've been having sporadic network problems since I upgraded the firmware on the router. Unfortunately I upgraded the firmware on the router be...
Oct 30, 2019Guru - Experienced User
Try another factory reset on the RBS with a wired PC connected to it. Wait about 4-5 minutes. IF the RBS is still working, the PC will get a IP address. You can access the RBS web page at 192.168.1.250 with a web browser. If you can get here, load the FW file to the RBS. Factory reset the RBS and setup from scratch.
- treadpoolOct 30, 2019Tutor
Thanks. To be clear, what are the steps for a factory reset for the satellite? I've read various versions of the steps to take. What I have tried is:
- Insert paperclip and hold for 30 sec
- While still inserted, unplug the power
- While still inserted, plug in power and keep it there another 30 sec
That seem right?
- FURRYe38Oct 30, 2019Guru - Experienced User
While plugged in to the power, press the back button for 15 seconds then release.
