treadpool
Oct 30, 2019Tutor
RBS50 blinking white - cannot connect
My Orbi satellite is flashing white and I'm not sure why. I've been having sporadic network problems since I upgraded the firmware on the router. Unfortunately I upgraded the firmware on the router be...
Oct 30, 2019Guru - Experienced User
Try another factory reset on the RBS with a wired PC connected to it. Wait about 4-5 minutes. IF the RBS is still working, the PC will get a IP address. You can access the RBS web page at 192.168.1.250 with a web browser. If you can get here, load the FW file to the RBS. Factory reset the RBS and setup from scratch.
treadpool
Oct 30, 2019Tutor
Thanks. To be clear, what are the steps for a factory reset for the satellite? I've read various versions of the steps to take. What I have tried is:
- Insert paperclip and hold for 30 sec
- While still inserted, unplug the power
- While still inserted, plug in power and keep it there another 30 sec
That seem right?
- FURRYe38Oct 30, 2019Guru - Experienced User
While plugged in to the power, press the back button for 15 seconds then release.
