treadpool
Oct 30, 2019Tutor
RBS50 blinking white - cannot connect
My Orbi satellite is flashing white and I'm not sure why. I've been having sporadic network problems since I upgraded the firmware on the router. Unfortunately I upgraded the firmware on the router be...
treadpool
Oct 30, 2019Tutor
Thanks. To be clear, what are the steps for a factory reset for the satellite? I've read various versions of the steps to take. What I have tried is:
- Insert paperclip and hold for 30 sec
- While still inserted, unplug the power
- While still inserted, plug in power and keep it there another 30 sec
That seem right?
Oct 30, 2019Guru - Experienced User
While plugged in to the power, press the back button for 15 seconds then release.
