treadpool
Oct 30, 2019Tutor
RBS50 blinking white - cannot connect
My Orbi satellite is flashing white and I'm not sure why. I've been having sporadic network problems since I upgraded the firmware on the router. Unfortunately I upgraded the firmware on the router be...
Oct 30, 2019Guru - Experienced User
Hopefully a reset and connection with the wired PC to the RBS will be all they need. Hopefully.
treadpool
Oct 30, 2019Tutor
Ok so the simple reset didn't work. Resorted to TFTP which was successful and the img file was transferred. What am I supposed to do next? There's no ring light pulsing anymore and the green power led is solid. There's no response when I press the Sync button.
- CrimpOnOct 30, 2019Guru - Experienced User
Did you press the sync button on both the satellite and the router?
- treadpoolOct 30, 2019TutorYes. No pulsing at all on the satellite. Both sync buttons pressed.
Oh, gee. Does the satellite go through the color sequence as described on this web page?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
And, the satellite does not appear on the list of Attached Devices (at all)?
