DJWings
Aug 12, 2017Follower
RBS50 blinking white all the time
Hello,
I was away from home for nearly a month and had my RBS50 shutdown while my RBR50 was still running.
When I came back, I have reset the link between the router and sattelite but now even if the system detects properly the RBS50, this one is always blinking white.
I have reset/resync/rebooted but it stills blinks while the RBR50 is perfectly fine.
Both firmware are the same 1.12.0.18.
Any idea ?
Thank you.
Any idea ?
Thank you.
1 Reply
i would prob try a factory reset and start the install process from scratch as its prob auto updated and screwed something up , a factory reset should clear it
