edelhart
Jun 02, 2024Aspirant
RBS50 blinks white endlessly, I think I tried everything suggested here OR?
Hi Folks, It started with not able to sync anymore (magenta). Tried various reset methods (ao 30-30-30). Removed the RBS from the connected satelite list. Reinstalled the firmware via the webinte...
- Jun 04, 2024
thanks for the confirmation
I appreciate it that an expert is willing to respond again on this question (apparently an intrinsic flaw happening in time in Orbi systems...)
Jun 03, 2024Guru - Experienced User
Have you factory reset the RBR and setup the hole system from scratch?
I presume if a FR and setup from scratch fails and you've done a 30-30-30 reset, possible the one RBS is bad.
edelhart
Jun 04, 2024Aspirant
Thanks for the response, but I tried that too...
The satelite is also not visbible at all (unless I connect it with a cable)
So I guess it doesn't send any wifi-signal. So I have to give it up đ
- FURRYe38Jun 04, 2024Guru - Experienced User
RBS may need to be replaced.
Good Luck.- edelhartJun 04, 2024Aspirant
I appreciate it that an expert is willing to respond again on this question (apparently an intrinsic flaw happening in time in Orbi systems...)- FURRYe38Jun 04, 2024Guru - Experienced User
Possible just a hardware failure on the RBS after long use.
