edelhart
Jun 02, 2024Aspirant
RBS50 blinks white endlessly, I think I tried everything suggested here OR?
Hi Folks, It started with not able to sync anymore (magenta). Tried various reset methods (ao 30-30-30). Removed the RBS from the connected satelite list. Reinstalled the firmware via the webinte...
- Jun 04, 2024
thanks for the confirmation
I appreciate it that an expert is willing to respond again on this question (apparently an intrinsic flaw happening in time in Orbi systems...)
edelhart
Jun 04, 2024Aspirant
Thanks for the response, but I tried that too...
The satelite is also not visbible at all (unless I connect it with a cable)
So I guess it doesn't send any wifi-signal. So I have to give it up 😞
Jun 04, 2024Guru - Experienced User
RBS may need to be replaced.
Good Luck.
- edelhartJun 04, 2024Aspirant
I appreciate it that an expert is willing to respond again on this question (apparently an intrinsic flaw happening in time in Orbi systems...)- FURRYe38Jun 04, 2024Guru - Experienced User
Possible just a hardware failure on the RBS after long use.
