edelhart
Jun 02, 2024Aspirant
RBS50 blinks white endlessly, I think I tried everything suggested here OR?
Hi Folks, It started with not able to sync anymore (magenta). Tried various reset methods (ao 30-30-30). Removed the RBS from the connected satelite list. Reinstalled the firmware via the webinte...
- Jun 04, 2024
thanks for the confirmation
I appreciate it that an expert is willing to respond again on this question (apparently an intrinsic flaw happening in time in Orbi systems...)
Jun 04, 2024Guru - Experienced User
RBS may need to be replaced.
Good Luck.
edelhart
Jun 04, 2024Aspirant
- FURRYe38Jun 04, 2024Guru - Experienced User
Possible just a hardware failure on the RBS after long use.
