lando786
Mar 12, 2020Aspirant
RBS50 Bricked?
So I'm not sure what changed recently but all of a sudden my RBS50 satellite was not connected to my RBR50. I tried rebooting via power, no white ring LED is visible, just the green power light on t...
Mar 12, 2020Guru - Experienced User
you can try a tftp procedure to recover it
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
make sure you enable it within windows
lando786
Mar 13, 2020Aspirant
I tried this but my pc doesn't even recognize the satellite as being connected. Sadly im out of warranty period and outta luck it seems.
- Retired_MemberMar 14, 2020
how do you know your sat is not connected? What are you looking at? What's connected to the sat?
- lando786Mar 14, 2020Aspirant
Connected directly to PC, pc sees cable as unplugged. Tried several cables/pcs. The reason I tried direct connection to PC is to attempt a TFTP fw upgrade. Without anything connected I tried syncing, it never syncs and the factory reset button does nothing no matter how long I press it.
