jdebler
Nov 09, 2020Aspirant
RBS50 Broadcasting Slow WiFi Signal, but Hardwired Works Great?
I have an RBR50/RBS50 system. The RBR50 is in the middle of the house and wifi speeds when near it are great with any decvice. However, RBS50 in my office has very slow wifi speeds, even when I h...
- Nov 09, 2020
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Nov 09, 2020Guru - Experienced User
- jdeblerNov 10, 2020Aspirant
After looking into your suggestions, I did a complete factory reset and reset it up from sctratch seemed to do the trick.
Note that I did a factory reset not by pushing the little button on the back with a paperclip (I tried that a few times), but going into the router settings, clicking on Advanced > Backup Settings > and hitting the Erase button under "Revert to Factory Default Settings".
- FURRYe38Nov 11, 2020Guru - Experienced User
Awesome. Glad that it's working now. Pressing the button in back for 15 seconds then release should work as well.
Enjoy, :smileywink:
