Corrales_Bob's avatar
Corrales_Bob
Follower
Nov 22, 2019
RBS50 compatibility
Which Orbi whole home systems are compatible with the RBS50 satellite?
  • FURRYe38's avatar
    Nov 22, 2019
    I believe all Orbi systems are compatible. Just be aware that the 20, 30 and 40 series Orbis differ in wireless backhaul speed support from the 50 series. 50 Series backhaul supports up to 1733Mbps while all the other models support up to 866Mbps only.
