WireDawg
Jun 26, 2019Aspirant
RBS50 config sync with Internet access
Two issues: 1 - satellite 2 stuck in config sync but it was providing verified Internet access to a device connected by Ethernet cable and also apparently wirelessly to two iOS devices. 2 - Another...
- Jun 26, 2019
Do you administer the Orbi using the web interface or a smartphone app?
There have been several questions raised about Access Control and the smartphone app, e.g. Orbi is not doing what it is supposed to.
One quick check is to disable Access Control (turn it off), then reboot: router first, satellite 1, then satellite 2.
CrimpOn
Jun 26, 2019Guru - Experienced User
WireDawg
I administer with the web interface but observe frequently with iPad app - no actual changes are made to configuration with the app.
i was ready to attempt your suggestion and powered up the satellite (sat 2) for the first time today and voila, it almost immediately achieved a blue ring and the web app showed direct connection to the router, problem magically corrected itself. I hope it lasts. By the way, this is the first problem I’ve had with my Orbi system in over 17 months since purchase.
Thanks for for the assistance! Also, do you know to force the RBR50 router to only accept manual firmware updates? I can’t find that option anywhere in the web interface pages.
- CrimpOnJun 26, 2019Guru - Experienced User
My understanding that as of the current firmware, Orbi does like other Netgear routers: when a firmware update is available, a notice pops up and the user can opt to update (or not). This has the obvious "downside" that thousands of systems will not get security patches because the owners never look at them. If my understanding is incorrect, someone will surely point out my error.
- WireDawgJun 26, 2019Aspirant
The connection did not last but a minute. I’m trying your suggestion of rebooting the router, sat 1and sat 2 in order. Sat 1 connected before I could reboot it, sat 2 connected with a poor status after I de-powered it, waited 30 seconds and then powered it on. That was the only way I found to reboot them as the web interface page does not have a reboot button for either satellite.
