CJK440
Nov 23, 2021Tutor
RBS50 Connection type 2.4GHz
I had an RBK50V2 system for a while and wanted to add a 2nd satellite. I bought a second hand RBS50 and added it in a hub/spoke config with daisy chain turned off. With both Sats similar distance...
Nov 23, 2021Guru - Experienced User
With both Sats similar distance (20' direct but on a second floor) the RBS50 that I added as a second shows a 2.4 connectiont type while the original 50V2 shows 5GHz. 20feet is too close. 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Try swapping RBS around with each other to see if problem follows or not.
I tried reflashing to the latest (same firmware and tryed resynching half the distance closer to the router with it still going to 2.4.Be sure the RBR and all RBS are using same version of FW.
Is there possible some settings on the second hand RBS thats limiting it?
